Mausberry Switch Script
Re: Mausberry Switch Script
Postby rastus » 22 May 2016, 01:01
rastus
Postby PeteB » 22 May 2016, 04:33
That looks really great! I see you found a place for your shell casing (chuckle). Thanks for sharing the pics.
Cheers,
Pete
PeteB
Postby rastus » 22 May 2016, 06:15
It is a shell casing, I thought so.... LoL! Don't tell me it's an on/off button too, or I'll shoot myself!
rastus
Postby thedman! » 22 May 2016, 09:53
Hi Folks,
Thanks for the comments.
Rastus, the screen is the official 7" raspberry pi screen, more details here:
Yep, that is the on/off button! :D
thedman!
Postby rastus » 22 May 2016, 10:30
rastus
Postby krieghund » 23 Nov 2016, 02:58
Sorry if this is a dumb question, but I made the above changes changes to my "carsetupArch.sh" (I assume this is the new version since it's on the Mausberry web site)
[Install]
WantedBy=multi-user.target' > /usr/lib/systemd/system/mausberry.service
systemctl enable mausberry.service
and I get the following error:
[root@runeaudio ~]# bash carsetupArch.sh
carsetupArch.sh: line 60: [Install]: command not found
carsetupArch.sh: line 61: unexpected EOF while looking for matching `''
carsetupArch.sh: line 63: syntax error: unexpected end of file
I get the following error when I remove the apostrophe:
Failed to execute operation: Unit file is masked
Any help would be appreciated. Thank you!
krieghund
Postby paul334 » 31 Dec 2016, 16:19
Sorry to resurrect an old thread, but this seems the best place for my question. I've got a set-up the same as this (except for the awesome Walnut mount!) and I was wondering if anyone could advise me.
The Mausberry switch works perfectly for powering the unit up/down, but if I shut down via the GUI shut down option, it doesn't trigger the mausberry. Is there a simple way to add a call to the mausberry shut down script from the GUI shut down option?
Cheers,
Paul
paul334
Postby hondagx35 » 31 Dec 2016, 19:04
Postby paul334 » 01 Jan 2017, 21:42
Thanks for your quick response. I tried adding the echo to the shutdown script with no success. Just typing the command doesn't seem to do anything either.
I've checked the setup and it is using the default gpio 23&24, but directly echoing the gpio doesn't seem to do anything. :?
paul334
Postby hondagx35 » 01 Jan 2017, 22:06
Hi paul334,
do you use a momentary push button or a discreet on-off switch?
I think it would be best to ask the manufacturer if it is possible to shut down by command.
Users browsing this forum: No registered users and 100 guests
