The Raspberry Pi 3
Re: The Raspberry Pi 3
Postby mrcrowley » 23 Jun 2016, 07:26
Nobody try this ?
Inviato dal mio HTC One utilizzando Tapatalk
mrcrowley
Postby rocklander » 24 Jun 2016, 12:42
rocklander
Postby pistollero » 25 Jun 2016, 11:26
hello i have speed boot issues too:
[root@runeaudio ~]# systemd-analyze
Startup finished in 3.550s (kernel) + 1min 31.381s (userspace) = 1min 34.931s
[root@runeaudio ~]# journalctl
-- Logs begin at Mon 2016-02-22 15:40:15 CET, end at Sat 2016-06-25 12:29:26 CEST. --
Feb 22 15:40:15 runeaudio systemd-journald[135]: Runtime journal (/run/log/journal/) is 5.7M, max 46.1M, 40.3M free.
Feb 22 15:40:15 runeaudio kernel: Booting Linux on physical CPU 0x0
Feb 22 15:40:15 runeaudio kernel: Initializing cgroup subsys cpuset
Feb 22 15:40:15 runeaudio kernel: Initializing cgroup subsys cpuacct
Feb 22 15:40:15 runeaudio kernel: Linux version 4.1.20-1-ARCH (builduser@leming) (gcc version 5.3.0 (GCC) ) #1 SMP Sat Mar 19 20:07:23 MDT 2016
Feb 22 15:40:15 runeaudio kernel: CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
Feb 22 15:40:15 runeaudio kernel: CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Feb 22 15:40:15 runeaudio kernel: Machine model: Raspberry Pi 3 Model B Rev 1.2
Feb 22 15:40:15 runeaudio kernel: cma: Reserved 8 MiB at 0x3a400000
Feb 22 15:40:15 runeaudio kernel: Memory policy: Data cache writealloc
Feb 22 15:40:15 runeaudio kernel: On node 0 totalpages: 241664
Feb 22 15:40:15 runeaudio kernel: free_area_init_node: node 0, pgdat 80b88cc0, node_mem_map b9bb4000
Feb 22 15:40:15 runeaudio kernel: Normal zone: 2124 pages used for memmap
Feb 22 15:40:15 runeaudio kernel: Normal zone: 0 pages reserved
Feb 22 15:40:15 runeaudio kernel: Normal zone: 241664 pages, LIFO batch:31
Feb 22 15:40:15 runeaudio kernel: [bcm2709_smp_init_cpus] enter (9380->f3003010)
Feb 22 15:40:15 runeaudio kernel: [bcm2709_smp_init_cpus] ncores=4
Feb 22 15:40:15 runeaudio kernel: PERCPU: Embedded 13 pages/cpu @bafac000 s21132 r8192 d23924 u53248
Feb 22 15:40:15 runeaudio kernel: pcpu-alloc: s21132 r8192 d23924 u53248 alloc=13*4096
Feb 22 15:40:15 runeaudio kernel: pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
Feb 22 15:40:15 runeaudio kernel: Built 1 zonelists in Zone order, mobility grouping on. Total pages: 239540
Feb 22 15:40:15 runeaudio kernel: Kernel command line: 8250.nr_uarts=1 dma.dmachans=0x7f35 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2709.boardrev=0xa02082 bcm2
Feb 22 15:40:15 runeaudio kernel: PID hash table entries: 4096 (order: 2, 16384 bytes)
Feb 22 15:40:15 runeaudio kernel: Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Feb 22 15:40:15 runeaudio kernel: Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Feb 22 15:40:15 runeaudio kernel: Memory: 936208K/966656K available (7904K kernel code, 676K rwdata, 2840K rodata, 412K init, 780K bss, 22256K reserved, 8192K cma-reser
Feb 22 15:40:15 runeaudio kernel: Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xbb800000 - 0xff000000 (1080 MB)
lowmem : 0x80000000 - 0xbb000000 ( 944 MB)
modules : 0x7f000000 - 0x80000000 ( 16 MB)
.text : 0x80008000 - 0x80a86280 (10745 kB)
.init : 0x80a87000 - 0x80aee000 ( 412 kB)
.data : 0x80aee000 - 0x80b97048 ( 677 kB)
.bss : 0x80b9a000 - 0x80c5d33c ( 781 kB)
Feb 22 15:40:15 runeaudio kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
Feb 22 15:40:15 runeaudio kernel: Hierarchical RCU implementation.
Feb 22 15:40:15 runeaudio kernel: NR_IRQS:608
Feb 22 15:40:15 runeaudio kernel: Architected cp15 timer(s) running at 19.20MHz (phys).
Feb 22 15:40:15 runeaudio kernel: clocksource arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
pistollero
Postby mrcrowley » 25 Jun 2016, 11:42
Is it normal that from Debug Data I have "HW platform: RaspberryPi2 (08)" ???
It should be a Raspberry Pi 3 !!
Bye
mrcrowley
Postby pistollero » 25 Jun 2016, 20:04
pistollero
Postby hondagx35 » 26 Jun 2016, 21:28
Postby mrcrowley » 27 Jun 2016, 08:37
Ok. And what about Bluetooth control ??
Thank you. Great job !!
Edited ... See down.
mrcrowley
Postby mrcrowley » 29 Jun 2016, 10:49
After a try with Rune Audio Remote Control, I would say that it could be a good idea to use the integreated Bluetooth feature of Raspberry 3 to control it directly with RARC.
mrcrowley
Postby mrcrowley » 16 Oct 2016, 09:31
No one care about this idea ?
Is Rune project dead ?
mrcrowley
Postby hondagx35 » 16 Oct 2016, 11:47
