raspberry pi 2 "shut down" after a while
Postby oshimapt » 14 Jul 2016, 11:17
hi guys!
first, great project here!!!
well, i have a raspberry pi2 with a hifi berry digi plus card. it works really well. the sound is good, no crackling or strange noises.
the problem is that if it stays too much time in idle i look like the pi shuts it self down. even the light of the network connection on the router its off.
i though it was problem of the pi or sd card, but if i use volumio this do not happens.
it happens with dhe beta 0.3 and 0.4.
any ideas?
oshimapt
Re: raspberry pi 2 "shut down" after a while
Postby dror » 14 Jul 2016, 15:42
Could this be the same issue I am facing? =>
mount-not-responding-problem-t3811.html
dror
Postby chrisryburn » 15 Jul 2016, 08:45
Hi, I've been using Runeaudio on my Raspberry Pi2 b for a while now using the 03/2016 version. Love it, but, I have same issues where the Raspberry does appear to freeze. I have noted that it sometimes happens when I've been using Spotify. It is noted that Spotify in Rune is 'experimental', and it is a bit glitchy (I use it a lot). When it plays up, you've got to try and get back to MPD, reboot and everything is usually ok. If you don;t use Spotify I guess this is a waste of space reply!
chrisryburn
Postby oshimapt » 15 Jul 2016, 09:21
@chrisryburn:
don't think so. my mout and works really well.
try to configure guess access on the windows machine and try it. or you could use a password on the windows machine.
@dror:
no i do not use spotify. it happens even if it isn't doing a thing.
any way, i think i found the problem. it seems to be on the power supply. i was using the usb charg future of my desktop, and it boot ok, but after a while it look like was dead.
after reading some faq about the pi, i notice that the powerled do no remain lid. this indicates prolems on the power supply. saw this here: http://www.runeaudio.com/documentation/ ... eshooting/
changed to a good power supply, the led remains lid and the pi looks more stable.
thanks for the help and hope this helps other too.
oshimapt
Postby hondagx35 » 15 Jul 2016, 11:48
Users browsing this forum: Bing [Bot] and 21 guests
