i2S port \ DAC SABRE MK2 ES 9018 HELP !!
Re: i2S port \ DAC SABRE MK2 ES 9018 HELP !!
Postby alvaron » 16 Oct 2016, 02:40
Hi Frank
now all is OK....even the display backlight is working as it should ....at first I had a problem that
the screen went off and had difficulty getting it back working but I finally did it.. I presume that these sys commands
stay after rebooting.
Regarding the sabre ES9018mk2 is working fine with no problem at all..
Many thanks again..Frank
alvaron
Postby dunghnguyen » 16 Oct 2016, 09:22
dunghnguyen
Postby hondagx35 » 16 Oct 2016, 10:40
Postby hondagx35 » 16 Oct 2016, 10:42
Postby dunghnguyen » 16 Oct 2016, 12:13
dunghnguyen
Postby dunghnguyen » 16 Oct 2016, 12:16
@alvaron: can you quote the config.txt how you did for it? ... still dtoverlay=sabreberry32?
dunghnguyen
Postby hondagx35 » 16 Oct 2016, 12:21
Postby alvaron » 16 Oct 2016, 16:20
Hi Frank and dunghnguyen I was away and just returned to my shack.
I am using hifiberry dac in my config.sys wit i2sparameters on
the DAC is the Audiophonics ES9018Mk2 board....connected with just 4 i2s lines to the Pi3
the word lenght is 24 as instructed by you Frank !!!
Alvaro
alvaron
Postby dunghnguyen » 17 Oct 2016, 02:35
dunghnguyen
Postby dunghnguyen » 17 Oct 2016, 06:58
This is of journal of my case:
http://pastebin.com/uAxCQ2rR
This is the debug in my case:
http://pastebin.com/XGGbMMSC
Please advise if any
Thanks.
dunghnguyen
