Runeaudio fileserver function?
Postby pasdesignal » 05 Aug 2014, 05:48
I may be missing something here, but I have done my best to solve this on my own...
Does runeaudio serve files to a network? Like using Samba as a server or NFS or something?
I am running 0.3 on a Raspberry Pi B+. Loving the performance. Using a homemade USB DAC, MPOD client, airplay.
Just wondering if I can enable the file server somehow....?
(PS: nice work on the distro. Its very tidy and smooth playback - no issues whatsoever with USB DAC output.)
pasdesignal
Re: Runeaudio fileserver function?
Postby Orion » 05 Aug 2014, 12:02
Hi pasdesignal,
yes. For now, you have to enable the DEV mode.
Take a look here
- Embedded Hi-Fi music player
Orion
Postby pasdesignal » 10 Aug 2014, 07:52
Hi Orion, thanks for the reply.
I tried the "DEV" feature you linked to above, and indeed it did enable a Samba type fileserver. However I didnt have write capability when using the feature as a guest.
Is there a samba user that I should use, or is there a way to enable write permissions for all users on the samba share?
Maybe this idea belongs in "Feature requests". I think it is an important feature because how else is one supposed to add music to our library without unplugging the hard-drive and using another machine. A fully functional samba share with default write permissions is the easiest way to do this, and is implemented on Volumio to great effect.
Interested in your thoughts.
pasdesignal
Postby ghashul » 13 Aug 2014, 00:11
I have enabled dev mode as described on my rPi b+ with 0.3, but samba doesn't appear to be running. I can't connect from Windows, so I tried logging in via SSH and checked if smbd was running, which it isn't. Is there something more I need to do?
ghashul
Postby franz159 » 17 Aug 2014, 09:52
franz159
