Pi Zero No soundcards found (solved)
Postby wim-nl » 19 Nov 2016, 17:24
No soundcards on RP zero
This is what i found in this forum and i did all of this:
pacman -Sy --force raspberrypi-firmware-bootloader linux-raspberrypi
sync
cmdline.txt:
root=/dev/mmcblk0p5 rw rootwait console=ttyAMA0,115200 console=tty1 selinux=0 plymouth.enable=0 smsc95xx.turbo_mode=N dwc_otg.lpm_enable=0 kgdboc=ttyAMA0,115200 elevator=noop
config.txt:
# RuneAudio settings
cmdline=cmdline.txt
kernel=kernel.img
dtoverlay=hifiberry-dac
I²S kernel modules is loaded --> HiFiBerryDAC
When i connect a $1 usb soudcard, that is detected ok and works ok!
http://pastebin.com/L0PT4KGZ for the debug info.
wim-nl
Re: Pi Zero No soundcards found
Postby hondagx35 » 19 Nov 2016, 18:36
Hi wim-nl,
please try this:
- delete the file /etc/modules-load.d/ras....conf
- delete the file /etc/modprobe.d/snd-soc-pcm512x.conf
- reboot
Postby wim-nl » 19 Nov 2016, 18:57
No, no result. Still no soundcards visible.
I also disabled and enabled again hifiBerry, no result.
BTW : Linux Kernel shows Linux kernel 3.12.26-1 and not Linux version 4.4.32-3-ARCH
wim-nl
Postby hondagx35 » 20 Nov 2016, 00:13
Postby wim-nl » 20 Nov 2016, 10:40
I've got my Pi Zero working!
I have flashed the old, original 0.3 image, applied all above and it worked out of the box.
Up and playing in 32 seconds !
Down in 15 sec.
Thx for support.
wim-nl
