Beta v0.2 Playlist issue
Postby supertrogg » 23 Jan 2014, 16:32
On Windows 7/IE11 the playlist is stuck on a previously played album. It never changes if I add, replace, play from the Browse tab. The playing track is highlighted though and the playing track can be changed. Tracks cannot be deleted from the list. If there are fewer tracks in the actual playing album than are displayed in the Playlist view then nothing happens. The current track continues playing.
I have tried:
closing the tab, no change in behaviour on re-launch.
closing IE, no change in behaviour on re-launch.
re-booting Pi, no change in behaviour on re-launch.
However, on OSX Mavericks and iPad4 the Playlist works as intended!
supertrogg
Re: Beta v0.2 Playlist issue
Postby ACX » 23 Jan 2014, 19:58
I just tested it on IE11 and Win8 and everything works as supposed (and surprisingly fast, I must admit! has Microsoft finally released a decent web browser? :) ).
Are you sure you don't have some parts of the old version in cache? Try to hard-refresh the UI with CTRL+F5 and please tell me if it fixes the problem.
Postby supertrogg » 23 Jan 2014, 21:22
Thanks for the reply. Unfortunately that made no difference!
supertrogg
Postby Stino » 27 May 2014, 12:26
Same here, EI 11 doesn't display playlists properly, playlists work in Firefox 29.01.
Stino
Return to Bug report
