Make buttons larger
Make buttons larger
Postby ColinT » 20 Jan 2017, 10:40
hello all,
i am using rune audio on a RPi 2B with the raspberry touchscreen.
i want to make the play controls and the bottom menu's larger.
i read this topic: support-for-7-touchscreen-monitor-for-raspberry-pi-t2868.html
and tried to do do it but nothing was happening. which part of the css do i have to edit to get it working?
thanks,
Colin
ColinT
Re: Make buttons larger
Postby rern » 20 Jan 2017, 12:50
This should make it easier to start with.
Postby ColinT » 20 Jan 2017, 14:07
I have installed it, GPIO function is super! going to need it in the future.
But how do i make the buttons bigger?
ColinT
Postby rern » 20 Jan 2017, 15:35
in /srv/http/assets/css/custom.css:
There are couple of #menu-top and #menu-bottom items to play with.
Postby gabcosse » 20 Jan 2017, 17:10
Hi. In that file there is something for make the album image larger?
Tnx
Inviato dal mio Nexus 5 utilizzando Tapatalk
gabcosse
Postby rern » 21 Jan 2017, 01:23
#coverart
and
#cover-art
Postby ColinT » 21 Jan 2017, 15:45
Thanks RERN for you help.
i now have a bigger interface, but.... :)
now the middle part is not fitting anymore, how can i adjust it to make it fit?
also the top en bottom menu do not disappear any more.
some screenshots attached
screenshots
ColinT
Postby rern » 21 Jan 2017, 21:33
middle part
order, -webkit-order (1-6)
top, bottom
top, bottom (px)
Postby ColinT » 22 Jan 2017, 14:34
hello rern,
your solution in custom.js works, thanks.
your solution in custom.css did not work, this only makes the space between the time-knob and the buttons smaller.
is there another option that i can do?
thanks for your help so far :)
ColinT
ColinT
Postby rern » 22 Jan 2017, 15:38
display: flex;
flex-flow: row wrap;
#time-knob ------- #coverart ---- #volume-knob
#play-group ---- #share-group --- #vol-group
order: n;
width: n%;
max-width: npx;
each of above flow left to right, wrap to new row on full
The #coverart was hidden so the rest moved up to filled the place instead.
Users browsing this forum: No registered users and 40 guests
