Make buttons larger
Re: Make buttons larger
Postby ColinT » 22 Jan 2017, 16:43
ColinT
Postby rern » 23 Jan 2017, 03:34
Postby ColinT » 23 Jan 2017, 07:39
Hello rern,
I do not want a larger cover art, that was a queation from gabcosse.
I want bigger buttons :D the part making them bigger worked. Now is the problem that a part from the center/middle screen with the knobs is falling behind the bigger menu buttons.
As you can see on the screenshots i my previous post.
And my question is: how can i adjust the middle part fit back again between de bigger menu's :)
I added my css for you, that way you can make a example:)
I also have a second question: is it plossible to change the state of the GPIO's?
When they are off it is HI and when on it is LO, if plossible i want it reversed so off is LO and on is HI.
Thanks,
ColinT
ColinT
Postby rern » 25 Jan 2017, 00:56
As of your screen captures, I assume you turn off Display album cover.
Another CSS was added to fix this no-coverart layout.
If it's the case, uninstall and reinstall again should solve your issue.
Postby ColinT » 25 Jan 2017, 19:46
Hello rern,
The new web interface is finished.
With a little help from Google Chrome i could inspect the css code and made the correct adjustments in runeui.css and custom.css.
Buttons are larger, share-group removed, middle part Network Browser+Queue+Playback fixed, text in submenu's bigger.
This are very nice improvements if you use the Raspberry Pi 7" touchscreen.
I have add the files i adjusted.
Only my question for the GPIO's is still unanswered, could you help me with it?
Many thanks for you help
ColinT
New interface.zip
(30.61 KiB) Downloaded 353 times
ColinT
Postby rern » 25 Jan 2017, 20:29
Good to hear that you can do it. This will encourage anyone to try and share.
For the GPIO question, please ask in . I'll answer you there.
Users browsing this forum: No registered users and 33 guests
