Autostart Rune Audio after booting the Raspberry PI 3 B
Postby reinder » 12 Nov 2016, 08:59
I want to use the RuneAudio player always for the same audio stream
In an older version this was automaticle , that the Queue was played.
Now it is nescesarry to use the play button.
How can I make this automaticle.
reinder
Re: Autostart Rune Audio after booting the Raspberry PI 3 B
Postby dejaybaze » 02 Feb 2017, 16:56
I would like this feature as well....
dejaybaze
Postby Stephane » 08 Feb 2017, 21:37
It shouldn't be too difficult to do it with cron.
Create an entry in the root crontab to launch a script at startup (syntax: @boot ......., Google is your friend). The script should test if mpd is up and running and the send the play command with mpc.
This job needs a little bit of bash scripting skills. I will try to make one and post the result here.
Stephane
