Spotify playlists not visible
Re: Spotify playlists not visible
Postby purban1 » 17 Jan 2017, 17:02
I have the same problem, been working for 6 months and suddenly it stopped working. Now I only have Favorites to choose from.
purban1
Postby miskor » 17 Jan 2017, 19:34
Can this be due to the fact that spop is built upon libspotify which is deprecated and now maybe Spotify is blocking access?
Sent from my iPad using Tapatalk
miskor
Postby xcode » 19 Jan 2017, 05:22
xcode
Postby betocool » 25 Feb 2017, 13:36
betocool
Postby rlsten » 25 Feb 2017, 16:22
Spotify stopped working for me yesterday too. I can see my playlists, and when I try to play something the playback knob shows that something is being processed, but there is no sound.
I have no problems with mpd content via Network Mounts from my Synology NAS.
I am using an RPI2 via ethernet, latest Rune image.
Rod
rlsten
Postby rlsten » 25 Feb 2017, 17:44
Sorry for my last post. Already knew the answer per Frank:
Please try this while playing a song from spotify (no audio doesn't matter here)
- go to MENU->Mpd
- select "RaspberryPi Analog Out" as Audio interface.
- switch back to your DAC
rlsten
Postby betocool » 26 Feb 2017, 03:39
I wish I could see something on the playlist.
I get nothing. I do have Spotify playlists, but they don't show! Once they show, everything works fine.
betocool
Postby wookiee » 29 Mar 2017, 08:21
^same problem here...
wookiee
Postby irishwill2008 » 29 Mar 2017, 10:05
Is this a present bug still?
I can confirm that i am having NO troubles with spotify loading my user defined playlists. Everything loads as it should for me? I am not missing anything. I thought i would post this in case it is a regional issue? I am from Ireland. As stated, i am having no troubles?
P.s. In case i am blind, what is it that is not loading? The playlist section? Or the content inside the playlists? Either way, Mine has been working and i leave the machine on 24/7. So far, my pi is pi3 and im on v0.3-beta (23/03/2016) Version. I then did an update to the dev mode but i am not using the latest 0.4 (that recent one Frank published the other day!) Im still using the version before. But all is good on my end!
Will.
irishwill2008
Postby wookiee » 29 Mar 2017, 13:37
^nothing's loading
when you click on Spotify, it just shows a folder which reads undefined. none of my playlists are showing :-(
I'm running a RPi 2 Model B with HifiBerry DAC2 on Rune v0.3-beta
wookiee
