Rasp freq
Rasp freq
Postby nickvas19 » 01 Mar 2017, 19:52
Hello to all i am new here
I dont know which is the lowest number can i put in these
arm_freq
gpu_freq
Core_freq
h264_freq
isp_freq
v3d_freq
sdram_freq
I make a quick search i didn t find something. If there a post explaining about freq inform me about it.
A big thanx
nickvas19
Re: Rasp freq
Postby ianhaynes » 01 Mar 2017, 20:04
This article by Archimago has some useful background.
Note that he appears to have got the syntax wrong in one of his settings, 'sdram_over_voltage' should be 'over_voltage_sdram'.
See this thread too.
Pi 2, Ver. 0.5b, IQAudio DAC+
ianhaynes
Re: Rasp freq
Postby nickvas19 » 01 Mar 2017, 21:34
thanx a lot for the quick replay. the second lik i read it before but it isn't step by step.
well for the first one...i go to config.txt...but there isn't # uncomment to overclock the arm"
what happens?!
also nothing saying in config.txt about voltage...so?!
nickvas19
Re: Rasp freq
Postby Discovery » 01 Mar 2017, 22:09
Hi nickvas19,
This link is step-by-step. Ask if you have any questions: tweaking-the-audio-performance-rpi3-t4301-40.html#p19327
Discovery
Re: Rasp freq
Postby nickvas19 » 01 Mar 2017, 22:14
i am begginer so sorry about asking.
i know what to change...but i go inside putty...i write sudo nano /boot/config.txt and then there isn't any to change about sdram etc...Do i must write it on my own?!
nickvas19
Re: Rasp freq
Postby Discovery » 01 Mar 2017, 22:17
Yes, sometimes these lines need to be added. ;)
Otherwise, change the lines that are already there.
Discovery
Re: Rasp freq
Postby nickvas19 » 01 Mar 2017, 22:35
i put 2 pics to tell me if i make a mistake somewhere.sorry is my first steps.
i started from # uncomment to overclock the arm"
Στιγμιότυπο οθόνης (3).png (108.49 KiB) Viewed 1529 times
nickvas19
Re: Rasp freq
Postby nickvas19 » 01 Mar 2017, 22:36
and the second...
Στιγμιότυπο οθόνης (4).png (57.7 KiB) Viewed 1528 times
nickvas19
Re: Rasp freq
Postby nickvas19 » 02 Mar 2017, 12:50
well in detail my steps.
audio output: ifi (by Amr)
volume control:disable
dsd: enabled
soundsignature : Archlinux default
airplay:off
local browser:off
aply reboot
after this i go to sudo nano /etc/modprobe.d/disable_rpi3_wifi_bt.conf and i put these
##wifi
blacklist brcmfmac
blacklist brcmutil
##bt
#blacklist btbcm
#blacklist hci_uart
systemctl disable netctl-auto@wlan0
also in nano /boot/cmdline.txt i leave everything as it is but i write before the quiet this all in one line.
dwc_otg.microframe_schedule=0 dwc_otg.nak_holdoff_enable=1 dwc_otg.fiq_fix_enable=0 smsc95xx.turbo_mode=N dwc_otg.lpm_enable=0 maxcpus=1 quiet
and in sudo nano /boot/config.txt i change the folllowing
gpu_mem=64 to 16
and in the end of all this logs i write the following
disable_pvt=1
avoid_pwm_pll=1
arm_freq=666
sdram_freq=333
core_freq=333
gpu_freq=300
over_voltage=-10
sdram_schmoo=0x02000020
over_voltage_sdram_p=-5
over_voltage_sdram_i=-14
over_voltage_sdram_c=-6
so i wll wait to tell if i am right i these modifications. thanx a lot in advanced
nickvas19
Re: Rasp freq
Postby Discovery » 02 Mar 2017, 15:07
Hi nickvas19,
Let's assume you've made the entries correctly - does RuneAudio still work? This is always the best test!
Does it sound better?
Discovery
Users browsing this forum: No registered users and 20 guests
