Automatically playing/restarting on boot
Postby ctmorse » 07 Mar 2017, 22:58
Hi All,
New to Raspberry Pi and Rune Audio. Looks awesome. Can't wait to start experimenting. Will be ordering a Raspberry Pi tonight.
I'm looking to setup 5 systems to play audio over 5 separate channels for a small facility.
One concern is needing user intervention in the case of a power failure or system reboot. When rune audio boots can it be set to automatically start playing audio from a USB flash drive or from a network location? Can it play a specific playlist at startup?
Is there any way to have it start playing where it left off? That is, could it start at the last track it was playing before the system restarted?
Thanks,
Chris
ctmorse
Re: Automatically playing/restarting on boot
Postby hondagx35 » 07 Mar 2017, 23:11
Postby ctmorse » 11 Mar 2017, 05:29
Thanks Frank. I will give it a try.
ctmorse
Postby elktamer » 13 Mar 2017, 17:07
Are there instructions on how to do that startup configuration?
elktamer
Postby hondagx35 » 13 Mar 2017, 23:24
Postby elktamer » 15 Mar 2017, 19:22
Frank,
Thank-you. I'm using it in a care home, and on/off is as much control as the user can handle.
elktamer
Postby ctmorse » 15 Mar 2017, 21:48
I gave the autoplay setting a try and it isn't working for me. Is there a particular way to store the audio files on the USB flash drive to get this to work? I had folders for each album inside folders for each artist. I was playing the tracks for one album, unplugged the RPi and plugged it back in but the audio did not automatically restart.
I also noticed that when I changed the default volume level and saved it, it reverted back to original value after a power loss.
Chris
ctmorse
Postby ashum » 02 May 2017, 12:54
I can not to set up automatically playing after power loss too.
ashum
Postby timflan » 09 Jun 2017, 19:12
New to RuneAudio, but got it working alright on my RPi 3/B.
Have installed the new beta, but can't get AutoPlay to work. It loads up the previously playing Queue, but in Stopped mode. I have to hit Play to start it playing. What am I doing wrong?
timflan
Postby hondagx35 » 09 Jun 2017, 20:46
Hi timflan,
did you reboot or unplug power?
The option "autoplay" is enabled?
