2.4GHz Airmouse as remote
Postby SlF » 16 Jan 2016, 14:35
SlF
Re: 2.4GHz Airmouse as remote
Postby hondagx35 » 16 Jan 2016, 18:01
Postby SlF » 31 Jan 2016, 12:18
SlF
Postby SlF » 31 Jan 2016, 14:16
Update: I updated the package lists with pacman -Sy and installed evtest. I found out, that the remote is recognized as a mouse AND a keyboard. The buttons are recognized as "KEY_VOLUMEDOWN" Damn nice!!! Only problem is, that I can't compile EMPCd, which I do need to map the buttons...
SlF
Postby hondagx35 » 31 Jan 2016, 15:42
Postby SlF » 31 Jan 2016, 17:44
SlF
Postby SlF » 31 Jan 2016, 18:16
Got it up and running thank you very much!!!
How can I make empcd autostart?
Best regards
Ole
SlF
Postby hondagx35 » 31 Jan 2016, 20:06
Postby SlF » 01 Feb 2016, 15:27
I now have a nearly perfect setup. Everthing is working perfect, I applied the service and it worked, but after changing the empcd config, the service doesn't work anymore... I need to manually start empcd in daemon mode now.
Thank you,
Ole
SlF
Postby yeongheon » 04 Aug 2017, 16:12
I am trying to setup 2.4GHz Airmouse too. According to your guide, I installed empcd and base-devel. And it seems that the Airmouse remote identified. But only volumeup and down are working.
So, I need to find Key name of mouse button to describe in empcd.conf. But I dont know.
How can I get the Keyname?
yeongheon
