Updating Raspian (pi OS) lost Pi ip address
Re: Updating Raspian (pi OS) lost Pi ip address
Postby hondagx35 » 05 Oct 2017, 21:30
Hi foxint,
how did get Rune running the first time?
I am sure you had to download the image from our server and flash it to the sd card, right?
Why should it be different this time?
- get a fresh sd card
- download the file from my link
- unzip the downloaded file (you should get a *.img file)
- flash it to the sd card
- insert the card and boot your Pi
Or better read the manual first
Postby foxint » 05 Oct 2017, 21:42
Hi Frank
Thank you.
I will give it a try...took me weeks...I vaguely remember I had to use my daughter’s old pc and do something with the card. It was not an easy thing.
I just got an email from the Pi2Media guy.
• He did not mention how to get the device to work…but
• He said I should disable the Wi-Fi and the Bluetooth
I have pi3 and did not know it had either of these.
How does one disable these?? As I understand the pi has your software now??
Thank you
foxint
Postby foxint » 06 Oct 2017, 08:12
Hi Guys
Back with some good news and the usual bad news.
I have all sorts of issues...basically there is no noise.
In setting....Frank said select: HiFi Berry Digi + Pro....there is no option exactly like this only: HifiBerry Digi Pro. Yes I tied this...Nothing.
I cannot find any other stuff for the Digi + pro. I am only getting on MPD (not sure what this is).... Analog out and HDMI.
I am using optical...that's all I ahve and it worked with the Digi +...but not with the Pi2 DAC Pro.
Sorry...but are they any step-by-step with pictures...yes I need pictures...But I think it (yes me guessing) may be the RuneOS kernal setting...sorry I am stuck again...
foxint
Postby hondagx35 » 06 Oct 2017, 09:39
Hi foxint,
did you reboot after setting the I2S driver?
And for the very last time:
No debug information => no support!
Select the driver on the settings page, reboot and send the debug info.
Postby foxint » 06 Oct 2017, 09:45
Hi Frank
Yes: thank you. I did reboot…many times.
I do not know what debug information is??
What about the difference between:
• HiFiBerry Digi + Pro and
• HiFiBerry Digi Pro without the “+”
I am very confused???
foxint
Postby hondagx35 » 06 Oct 2017, 09:56
Postby foxint » 06 Oct 2017, 10:05
Hi Frank
Thanks…I have Pi3 and Rune – RuneAudio_rpi2_rpi3_0.4-beta_20170220_2gb.img.gz. There is not help or about so I have no idea the version. I downloaded it as you suggested today
Not sure what information you need. How do I get it and what do you need??
• So HiFiBerry Digi Pro without the “+” will do the Pi2Media Dac 502
So, what must I do to make it go?
foxint
Postby rastus » 06 Oct 2017, 10:32
rastus
Postby hondagx35 » 06 Oct 2017, 10:38
Postby foxint » 06 Oct 2017, 10:41
Hi Mate
Thanks...but it really did not work. I pushed the "copy to clipboard" and I have no idea where it went???
So here is it for what it is worth...I have no idea what it means...hope someone does???
edit by hondagx35:
Debuginfo now on pastebin.
foxint
Users browsing this forum: No registered users and 20 guests
