Updating Raspian (pi OS) lost Pi ip address
Re: Updating Raspian (pi OS) lost Pi ip address
Postby foxint » 06 Oct 2017, 10:45
Why do I get the horrible feeling all is wrong???
foxint
Postby foxint » 06 Oct 2017, 10:54
Hi Frank
• I read the manufactures manual – it gave no instruction
• There are 4 lights on the board:
• 1 is the network light – on
• 3 other lights next to the ¼ inch out and the bottom green light is on
• I have plugged my optical cable into the board.
• The manual just said it would work.
Jumper W1…not sure what that is…There is a jumper (a small cover) that is over 2 pins, that I think changes it from taking power from the pi or an external power supply. I have changed nothing about the board. It is as it came. I just put it in the plastic case.
Sorry…but I have no idea what I have done.
foxint
Postby hondagx35 » 06 Oct 2017, 11:21
Postby foxint » 06 Oct 2017, 11:41
Hi Frank
Thank you.
Seems like there is progress…. you are very clever. Thank you.
I bought this: http://www.pi2design.com/502dac.html
Not sure why…it took a while. Perhaps I needed the Pro???
Why is my Dac not being recognised? It is the same Dac that was plugged into the HiFiBerry Digi with Optical cable.
“can you disable blue tooth” …No I have no idea how.
Michael from Pi2 said it would be best to disable blue tooth and wi-fi…but both are way beyond my capabilities.
Do you have a screen shot??
foxint
Postby foxint » 06 Oct 2017, 11:46
Hi Frank
I cannot find:
/boot/config.txt
Here is photo
foxint
Postby hondagx35 » 06 Oct 2017, 12:02
Postby foxint » 06 Oct 2017, 12:11
Sorry, I was confused as I was given the Pro Manual…so I thought it was a pro…I did not know until now there were 2.
I do have noise/music from the internet radio…. great THANK YOU.
Sorry to ask…. but what are the other settings I need to get right for the best sound….
I am an advocate, I really like the software…I am just rubbish at making it work
foxint
Postby rastus » 06 Oct 2017, 13:52
rastus
Postby foxint » 06 Oct 2017, 23:00
Hi Guys
Thank you all again for your help. As I said I like the software, but never could enjoy its full potential. But I keep plugging away when I get the enthusiasm
So sorry. I got it wrong. I did not realise what I had…also I did not realise that it would not work. My apologies for my mistake. The whole pi-thing is very confusing. I know it is second nature to some, but for me. it is a mine field.
If I may ask????
What are the other settings on the other pages I need to fix/change.
I am not sure what any of them should be. Now all I can hear is the radio…my flac/music files are somewhere on the network… (I have never been able to get this right – I gave up last time as it was too confusing)
Hope being a novice is still Ok to ask questions. Apologise for the bug thing…it just went pear shaped.
foxint
