Rune WiFi Only Connects To TKIP, Not AES
Postby R101 » 09 Dec 2017, 21:55
I have never managed to get Rune's wifi to connect to my router unless network encryption is set to TKIP rather than AES. No other device seems to have any problem.
The network configuration page in Rune's menu shows that it has recognized the SSID and that it requires AES, but it will not connect to it. If I change to TKIP, it connects with no problem.
As the router limits the connection speed for everything else on the network to "g" speeds if it is set to TKIP, I would rather like to sort this out. Is there an easy way to fix it?
Re: Rune WiFi Only Connects To TKIP, Not AES
Postby R101 » 10 Dec 2017, 13:39
Postby R101 » 11 Dec 2017, 21:01
After a bit more investigation, it seems generating a 256 bit key is not necessary.
The GUI setup writes values to the configuration file which deliberately restricts the encryption method to TKIP. If the configuration values were left as default, or set to CCMP TKIP, the problem would not arise.
Please can this be put on the list of things to look at?
Postby hondagx35 » 11 Dec 2017, 21:52
Postby R101 » 12 Dec 2017, 11:05
Thanks for the response, Frank.
Could this be something to do with my TP-Link router or the fact that my SSID is hidden? My display shows CCMP twice, rather than AES as yours does. I have only been able to connect to AES by editing the netctl file. If I enter both options CCMP TKIP, it seems to connect to either.
Postby hondagx35 » 12 Dec 2017, 11:26
Postby dror » 21 Dec 2017, 10:46
dror
