Sound Quality on Allo Boss Rev.1.2 between Rune / Volumio
Re: Sound Quality on Allo Boss Rev.1.2 between Rune / Volumi
Postby janui » 19 Jan 2018, 14:45
Postby PhilHill » 19 Jan 2018, 16:56
Hi Janui,
as mentioned in my Post before, after inserting
SOXR to mpd.conf,
MPD does not come back to life.
Restart with activated DEV(eloper) option in UI brings back an Error with Socket ?
Maybe MPD needs to be compiled with Sox support?
kind Regards,
Phil.
PhilHill
Postby PhilHill » 20 Jan 2018, 14:31
and again...
found in DMESG:
[ 6.551274] snd-allo-boss-dac soc:sound: ASoC: CODEC DAI pcm512x-hifi not registered
[ 6.551288] snd-allo-boss-dac soc:sound: snd_soc_register_card() failed: -517
[ 6.641858] snd-allo-boss-dac soc:sound: pcm512x-hifi <-> 3f203000.i2s mapping ok
anything to do with failure of SOXR in MPD.conf ?
PhilHill
Postby hondagx35 » 20 Jan 2018, 15:04
Postby PhilHill » 20 Jan 2018, 16:00
super...
und wie geht das ohne Kollateralschäden ?
:: mpd and mpd-rune are in conflict. Remove mpd-rune?
Gruß,
Phil.
PhilHill
Postby PhilHill » 20 Jan 2018, 20:05
Did some Homework..
(and began from Scratch after reckless approach with 'pacman -Syu' ...haha....
now running Kernel 4.9.77-1-ARCH
DMESG differs slightly.
(don't know if this is a Pain at all)
[ 6.122996] snd-allo-boss-dac soc:sound: ASoC: CPU DAI (null) not registered - will retry
[ 6.123006] snd-allo-boss-dac soc:sound: snd_soc_register_card() failed: -517
[ 6.124761] snd-allo-boss-dac soc:sound: ASoC: CODEC DAI pcm512x-hifi not registered - will retry
[ 6.124771] snd-allo-boss-dac soc:sound: snd_soc_register_card() failed: -517
[ 6.126119] 1-004d supply AVDD not found, using dummy regulator
[ 6.126159] 1-004d supply DVDD not found, using dummy regulator
[ 6.126198] 1-004d supply CPVDD not found, using dummy regulator
[ 6.232218] snd-allo-boss-dac soc:sound: pcm512x-hifi <-> 3f203000.i2s mapping ok
Now, how to update that MPD thang ?
(sry guys, i'm not into that programming thing, but really 'd like to do that testing with SOXR)
kind Regards,
Phil.
PhilHill
Postby janui » 21 Jan 2018, 18:35
Postby PhilHill » 22 Jan 2018, 17:14
Hi Janui,
Plugins and MPD update went flawless, (yip yip hoorai!) thanks for your Advice.
Edited different mpd.conf's and small script for fast switching between configs & reloading deamon.
1st Impression from upsampling 16/44 to 24/96 is a bit more Bass, Voices less transparent.
If Source is 24/96 or better, leave it untouched.
Will do more listening later, with a Pair of fresh Ears ;)
kind Regards,
Phil.
p.s. do i have to concern about this?
edit:
PCM5122 Parameters not accessible through port :8080 since updates
PhilHill
Postby janui » 23 Jan 2018, 12:20
Postby PhilHill » 23 Jan 2018, 16:03
PhilHill
