I would have liked to install RuneAudio in a VM to test it and thus answer my questions, but since it appears to only support Raspberries etc I am unable to do so (I have no Raspberry), so I have to ask instead.
If I understand correctly, I can tweak MPD's config file so that the ID3-tags I specify are used as a basis for organizing the music library - I am thinking primarily about adding support for the 'composer' tag and maybe also 'boxset'.
But can I also tweak/customize multiple views in the UI?
E.g., one view called Composers, that only includes 'composer' tag from 'classical' genre, and with sublevel listing 'album'. And then a second view called Classical artists that only includes 'artist' tag from 'classical' genre, with the same sublevel view. Giving me two entry points to the classical segment, as it were.
Will RuneAudio allow me to tweak the views in the UI so that I could have this setup, or will I be locked into the music presentation logic decided by the devs like in Plex and Emby?
