KALI reclocker and PIANO DAC giveaway
Re: KALI reclocker and PIANO DAC giveaway
Postby Fidelity089 » 17 May 2018, 10:41
Fidelity089
Postby hondagx35 » 17 May 2018, 17:35
Postby Fidelity089 » 17 May 2018, 18:33
Fidelity089
Postby janui » 17 May 2018, 22:17
Hi Fidelity089,
If it is a later kernel you need to solve the problem, this image could help: runeaudio-0-3-beta-for-raspberry-pi-t502-520.html#p23625
It is based on the previous version to Franks latest 0.4, but it is upgraded to Linux 4.9.63.1. It's stable but does not contain the latest enhancements.
Postby Fidelity089 » 23 May 2018, 21:01
Fidelity089
Postby janui » 24 May 2018, 08:25
Postby Fidelity089 » 24 May 2018, 21:45
Hi Janui,
thank you very much - all done as you suggested - and the Piano DAC 2.1 shows up as I2S device - but there´s no sound output at all
when not having activated the internal sound devices (HDMI & Jack)
If I activate them - sound output is ONLY on the left channel when Dual Mono mode is selected :-(
Had to change the MPD.conf device to hw: 1:0 due to the other cards..
I also tried this but without success...
sudo su
rm /var/lib/alsa/asound.state
CARD="$(cat /proc/asound/cards | grep "\[PianoDACPlus" | awk -F " " '{print $1}')"
alsactl init $CARD >/dev/null 2>&1
amixer -q -c $CARD set 'Dual Mode' 'Dual-Mono'
amixer -q -c $CARD set 'Digital' 100%
amixer -q -c $CARD set 'Subwoofer' 100%
alsactl store $CARD
here my debug file:
https://pastebin.com/39NZeE2U
Thank you for your effort and quick response - very much appreciated
regards
Fidelity089
Fidelity089
Postby janui » 26 May 2018, 14:54
Postby sec.time » 29 Jun 2018, 04:05
Hi all,
I bought a Kali reclocker alone for the raspberry 3B with Rune audio 0.4-beta.
Could anyone help on how to change the setup in RuneAudio to enable Kali?
I like to connect I2S signal direct my ESS9038 Pro DAC but I already stuck at enable Kali.
I try all the I2S Kernel Modules setting in 0.4-beta RuneOS Kernel Settings page, none of them could get Kali to lock on any signal when playing songs.
One thing I notice is does not matter what DAC I choose in I2S Kernel Modules, the MPD AUDIO OUTPUT do not have any addition I2S DAC items show up.
sec.time
Postby hondagx35 » 29 Jun 2018, 15:18
Hi sec.time,
all so called "slave DACs" should work with the KALI reclocker.
Slave means that the clock is generated by the source device (in this case, the RPi).
Many DACs are not only connected to I2S, but also need a I2C connection to work correctly.
If the DAC is not connected the kernel recognizes this and will not load the driver.
I would try the HiFiBerry DAC (without + and pro).
Users browsing this forum: No registered users and 25 guests
