I have flashed a new SD card with the latest 0.4 beta from Frank on a Raspberry PI 2B.  This works Ok UNTIL I make any changes (other than changing the time zone) on the Settings page.  At this point the ALSA mixer seems to get removed and I loose all ability to output audio from the 3.5mm Audio Jack., on the MPD / Audio Output Interface it says 'Nothing to Select'. I am not using a DAC and simply want to use the analog audio output.
My PI details are:
RuneAudio:	Ver. 0.4b build 20170229
Arch Kernel:	Linux runeaudio 4.4.39 ARCH+
Raspberry PI:	RaspberryPi2 (08)
Network:	Ethernet connected
DAC:		None, output via RPi 3.5mm audio socket
Chris
