RPi 3 B+
Re: RPi 3 B+
Postby fox.peko » 23 Aug 2018, 14:57
fox.peko
Re: RPi 3 B+
Postby tml3nr » 23 Aug 2018, 16:04
tml3nr
Re: RPi 3 B+
Postby fox.peko » 23 Aug 2018, 16:19
fox.peko
Re: RPi 3 B+
Postby tml3nr » 23 Aug 2018, 16:41
tml3nr
Re: RPi 3 B+
Postby fox.peko » 24 Aug 2018, 12:45
fox.peko
Re: RPi 3 B+
Postby GRUPP » 25 Aug 2018, 00:07
Hi all,
Total Noob here. "Built" my first Raspbery Pi device by connecting a Raspberry Pi 3 B+ board to a HiFiBerry DAC+ PRO. I installed tml3nr's build of RuneAudio onto an 8GB Class 4 SD inserted into a USB card reader.
The boot is failing. Nothing displays on the monitor I've connected to the HDMI port. The red light on the Raspberry Pi is steady and the green light is displaying a series of 3 flashes. According to a post I found elsewhere, this indicates that start.elf cannot be found. Any suggestions?
--Rick
GRUPP
Re: RPi 3 B+
Postby tml3nr » 25 Aug 2018, 04:02
tml3nr
Re: RPi 3 B+
Postby hondagx35 » 25 Aug 2018, 10:23
Re: RPi 3 B+
Postby GRUPP » 25 Aug 2018, 18:11
GRUPP
Re: RPi 3 B+
Postby GRUPP » 25 Aug 2018, 22:25
GRUPP
