Raspberry pie 3B+
Re: Raspberry pie 3B+
Postby cmh714 » 11 Feb 2019, 18:28
Postby R101 » 11 Feb 2019, 19:16
Andre,
The power supply might be 5V, but have you checked at the Pi and the HDD? Unless the lead is very short, you are probably losing at least a volt in it.
Postby janui » 11 Feb 2019, 22:16
Hi R101 & cmh714,
Thanks for your posts. Didn’t give power a thought until now. It is a known issue on the 3B+, boot power peaks cause problems, this happens even when a 3B in the same configuration had no problems.
A short HDD cable is potentially a very smart and simple solution.
Lets see if we can verify/clarify what is going on. Any other suggestions are very welcome.
Postby janui » 11 Feb 2019, 22:19
Postby andre_chang » 12 Feb 2019, 08:45
Hi janui:
Modifying the value of config. txt - > boot_delay = 2 < - - - 5-10 is not helpful... Sda1. device is still wrong after restart. Penultimate 1 minute 30 seconds..
PS. These problems will not happen on moode system. He can use usb-hdd to boot normally. There are no errors.
Andre
analyze blame.png (40.08 KiB) Viewed 1808 times
andre_chang
Postby andre_chang » 12 Feb 2019, 10:46
Hi janui & cmh714 & R101:
It took me a little time to test the above questions in other ways.. The USB power supply problem of PI3B & PI3B +.
I use 3.5 inch HDD - > connect SATA to USB card... 3.5 inch hard disk fully uses a separate 12V & 5V power supply!
SATA to USB Card Connecting to PI's USB Port & PI Hardware Supplied by Another 5V/4 Amp Power Supply
This method can completely eliminate the impact of power supply shortage.
Unfortunately.. RUNE will still prompt sda1. devie to wait 1:30 seconds in the boot process.
PS. Hard disk boot in Rune 0.3bata + PI3B environment. There is no such problem!
Testing these faults over and over again is time-consuming and very hard. Please give more praise to the rune team for their hard work.
Look forward to Janui reviewing the logs of sda1 & sda2...
Andre
andre_chang
Postby janui » 13 Feb 2019, 11:00
Postby andre_chang » 13 Feb 2019, 16:48
Hi janui:
This is the output you need:
Andre
andre_chang
Postby cmh714 » 13 Feb 2019, 17:17
does vfat = ext4???
Postby janui » 14 Feb 2019, 12:21
