Shut down command via URL
Postby mapchen » 06 Apr 2016, 18:38
I was searching for a way how to shut down my rasp pi via a browser url.
As you can do that in the runeaudio web gui it should be somehow possible. Reason i ask is because i want to control it via my home automation system. I am unfortunately not a linux expert.
If i have understood the client code correctly its using a form for submitting a shutdown command.
Br
Matthias
mapchen
Re: Shut down command via URL
Postby LarsP » 08 Feb 2019, 11:05
You're exactly asking what I want to know too :)
I hope someone knows it now, 3 years later :D
LarsP
Postby LarsP » 14 Feb 2019, 22:32
It's possible to play, pause, stop, load playlist, set volume by http command.
See: control-play-pause-volume-over-tcp-t3137.html
And: https://www.musicpd.org/doc/html/protoc ... and-setvol
As far as I understand, it are all commands to control the MPD engine. (and not the "Rune-Part") correct me if i'm wrong..
So if anyone knows a trick to shut down a RPI at a certain time, I'd like to hear that!
LarsP
Postby LarsP » 16 Feb 2019, 21:54
LarsP
Users browsing this forum: No registered users and 80 guests
