(Solved) enable i2s output on Raspberry model B+
Postby d-roby » 13 Dec 2019, 14:10
Hello.. i bought an i2s-spdif card for my Raspberry, but i cannot enable it.. i cannot find it in the config.txt
(i put the sd card on the PC)
my config.txt
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
# uncomment this if your display has a black border of unused pixels visible
# and your display can output without overscan
#disable_overscan=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
# uncomment if hdmi display is not detected and composite is being output
#hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=1
#hdmi_mode=1
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
#hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
#arm_freq=800
# for more options see http://elinux.org/RPi_config.txt
## Some over clocking settings, govenor already set to ondemand
##None
#arm_freq=700
#core_freq=250
#sdram_freq=400
#over_voltage=0
##Modest
#arm_freq=800
#core_freq=300
#sdram_freq=400
#over_voltage=0
##Medium
#arm_freq=900
#core_freq=333
#sdram_freq=450
#over_voltage=2
##High
#arm_freq=950
#core_freq=450
#sdram_freq=450
#over_voltage=6
##Turbo
#arm_freq=1000
#core_freq=500
#sdram_freq=500
#over_voltage=6
gpu_mem_512=16
gpu_mem_256=16
##CMA - Dynamic Memory Split (unsupported/broken)
#cma_lwm=16
#cma_hwm=32
#cma_offline_start=16
# RuneAudio settings
cmdline=cmdline_linux-arch-rpi_3.12.26-1-ARCH.txt
kernel=linux-arch-rpi_3.12.26-1-ARCH.img
any suggestion?
Many thanks in advance
Roberto
d-roby
Re: enable i2s output on Raspberry model B+
Postby eea123 » 13 Dec 2019, 19:55
Here is the help that I received to get mine going.
newbie-issue-w-i2s-card-s-t6335.html
Don't know if that will specifically help since I am using RCA line outs rather than the spdif output.
eea123
Postby d-roby » 13 Dec 2019, 20:40
d-roby
Postby eea123 » 14 Dec 2019, 03:35
Good to hear :).
eea123
Postby d-roby » 14 Dec 2019, 21:35
Solved,
i2s board was already in the list ;-)
d-roby
Postby eea123 » 15 Dec 2019, 18:24
eea123
