Hello! how do I set up a 5-inch touch screen in runeaudio to
Postby TrIV » 08 Jan 2020, 20:05
Hello! how do I set up a 5-inch touch screen in runeaudio to make touch control work?
Unfortunately, the data is saved in pdf format, and I can not attach them to this text, if they are required to resolve the issue, I can send an email.
I would like to control the program using the touch screen because it will be convenient for me.
TrIV
Re: Hello! how do I set up a 5-inch touch screen in runeaudi
Postby eea123 » 12 Jan 2020, 12:04
Is this something you've already bought and can't get connected or are you just thinking about have touch features? If it is the latter, I use the Rune Android App on both my phone and a cheap tablet - which is technically a touch interface.
eea123
Postby vinnychoff » 27 Feb 2020, 17:02
Hi, I was interested in this as I have a raspberry pi 3b plus with a touch screen. I wanted to control the hardware direct from the touch screen and be able to log in remote on the phone.
Is this possible?
I also did try to load the software but failed first time around. I see there is mention that it will not run on the raspberrypi 3 plus? Is this right?
Last question I only have the standard pi with no additional board. Should i add one?
Thanks in advance. Vinny
vinnychoff
Users browsing this forum: No registered users and 57 guests
