we (some friends from and near Wien, Österreich) have our little project up and running, and finally everything is like it should be, thanks to RuneAudio 0.3 alpha.
There was only one problem with playing Flac-files, instead of using the Hifiberry-I2S-module we had to use the module snd-soc-pcm1794a, as with the DDDAC1794-NOS the output is mono when playing FLAC-audio-files with our special setup.
It consists of a RaspberryPi-Model-B connected through I²S with a DIYINHK-isolator (for isolation of the I²S-signal between Raspberry and DAC) , which is wired to the DDDAC1794-NOS, designed by Doede Douma (http://www.dddac.com/dddac1794.html), using RuneAudio to play our files (Flacs up to 24bit/192kHZ, Mp3s...).
Here are som pics, for wireless-control there is an Edimax-EW-7811Un-wireless-adapter in one USB-port, the other is used for the external-hdd containing the music-files.
The aluminium-case is from ebay, it was used in East Germany in the 'Abteilung für Rationalisierungsmittelbau' long time ago, but perfect for our needs.
- 1a.jpeg (251.84 KiB) Viewed 14521 times
- 2.jpeg (246.31 KiB) Viewed 14521 times
- 4.jpeg (247.44 KiB) Viewed 14521 times
The sound really is unbelievable most of the times, of course depending on the input-file, you can't enhance a bad sound-production/mastering.
But when the input is good the output is awesome, mostly equal or beating the vinyl (of course there also remains the question of origin/production), but this leads to constant discussions between us, one favoring vinyl, the other digital. Let's take the best of both worlds.
So many thanks to the creators of RuneAudio, in our opinion it's the best software for Rpi-Audio right now!
