DAC MODULE PIFI ON RASPBERRY PI 2
Postby lepmor » 10 Nov 2020, 21:19
Guy sorry if i trouble i'm completly new on the forum and using runeaudio for the first time . Installed in a SD card and functioning with digital audio . My objective was to have it in function with Analog output so i bought a DAC module PIFI , hardware installed i select it on runeaudio configuration but nothing on output , tryed to connect a headphone but nothing . I see a red led always on in the board but i do not know the meaning because the board arrived with no manual , nothing .
someone can help me ?
lepmor
Re: DAC MODULE PIFI ON RASPBERRY PI 2
Postby surfninja » 10 Nov 2020, 23:34
you should state what version of Rune you are using.
I know I've used this DAC with e6, e5 and possibly others.
I think you need to use the hifiberry dac Pro+ drivers for .3 and .4. e5 and e6 you can select the dac in the system settings.
rAudio 1, Raspberry Pi 2B
rAudio 1, Raspberry Pi 4B
rAudio 1, Raspberry Pi Zero W
surfninja
Postby rastus » 11 Nov 2020, 20:46
rastus
Postby surfninja » 11 Nov 2020, 21:00
surfninja
Postby lepmor » 12 Nov 2020, 07:58
This is the image i have downloaded :
RuneAudio_rpi2_rp3_0.4-beta_20160321_2GB.img.gz
so means that i have to remove the comment in the file config.txt related to the HIFIBerry DAC+ ?
nothing other ? (for me is already a lot !!!!! ...find the file ... remember how to use sudo nano !!!! and find the right line in the file !!!! )
Thanks guys for the support , this evening i will try doing my best .
lepmor
Postby s.k. » 12 Nov 2020, 08:36
Better use the image from here
and follow the instructions on OP
RPi2B Rev 1.1, Allo DigiOne, ATXRaspi, 16x2 OLED display - running rAudio
s.k.
Postby lepmor » 12 Nov 2020, 15:17
Ok i will download a create a sd with this image . What is OP ?
have i to do the modification of the file config.txt or with this image "e6" i have to do nothing and my DAC module will be recognized automatically ?
lepmor
Postby s.k. » 12 Nov 2020, 15:20
OP = open post = the first post
Read it carefully
s.k.
Postby lepmor » 12 Nov 2020, 16:25
I have already downloaded the image , can you publish the link where to read this OP ? sorry but i do not understand if you mean the Open post of the page downloading image or where .
lepmor
Postby lepmor » 12 Nov 2020, 17:11
Can you publish the link of the OP .
ANyway considering that excluding the output audio analog , all was functioning .
At the end installing this version have i to modify the config.txt to have the PIFI in function or not ?
Is it necessary to modify others configuration files connected to the objective to have the analog output in function ?
lepmor
Users browsing this forum: No registered users and 37 guests
