Postby Julian M1 » 04 Feb 2021, 10:29
Thanks Ears. I am now able to find the manual settings and add my IP address in. My problem was that if you do not swipe in the first few seconds, there is no input possible on the app screen, only kill and start again. I got in and the app is working ok, as the interface already was through the web. I wanted the app for others in my household to use who are even less tech literate than me.
Slowly my Pi4 is turning into a usable music streamer and I am happy :)
Julian M1
Postby chasolla » 04 Feb 2021, 14:38
Thanks a lot Ears,
I prefer to use the app rather than a browser but had given up.
raudio used to change the ip address for my pi every now and again on update.
now it seems to have settled on ..............97
now I can update the ip address on the app and everything works beautifully.
Chas
rpi 3b+, iqaudio pidac+(generic), raudio1
chasolla
Postby Schorschi » 11 Feb 2021, 12:45
No Bluetooth support in the new Version?
RuneAudio is so simple and perfect as an audio player. I like it more than volumino and others.
But i miss Bluetooth support to play music from my smartphone directly over runeaudio .
Schorschi
Postby Ears of Tin » 11 Feb 2021, 14:35
Use the latest version for bluetooth - https://github.com/rern/rAudio-1
I send podcasts from my phone to the player and send music from the player to my bluetooth headphones.
Ears of Tin
Postby ashishkumarji » 25 Apr 2021, 10:50
I've tried all other alternatives but always come back to rune. its the best and simplest, long may it continue. Downloading for a new install now.
ashishkumarji
Postby curkuma » 26 Apr 2021, 19:54
curkuma
Postby Ears of Tin » 27 Apr 2021, 14:39
I've never been prompted for a PIN. But a first guess would be "1234" followed by "0000". I've seen these used as default codes in other applications involving Raspberry Pi's
Ears of Tin
Postby curkuma » 14 May 2021, 11:33
I update to Fedora 34, but I still get ask about PIN code.
I try 1234 and 0000 but don't work.
curkuma
Postby meisme » 08 Oct 2021, 18:57
Hi folks!
Been playing with the 0.4 build (autoplay embled) for a bit, and cant seem to get autoplay of music on boot. Music is stored on a USB drive.
Im trying to setup a simple player which will autoplay all mp3 files on a thumb drive when poered on. All shutdowns will be dirty.
If I can additionally also get to work as a reciever, BT or cast from phone, that would be fantastic!
If it doable in this build ? Thanks a ton folks!
p.s. Pi not available at the moment so no way to test.
meisme
Postby guglielmope » 25 Nov 2021, 16:14
Hello, I have installed the latest version of RuneAudio 0.5-beta on RPI 4 and it seems to work fine, but I cannot use the Rune Audio android App to control it. It can't find the server that I find with Crome. How can I solve the problem?
Regards
Guglielmo
guglielmope
