Happy update...
After few hours
of waiting the new stable version find all "lost" folders and everything work fine.
It's strange but something is unclear for me at BIT perfect settings. Both switches should be on Grey or on Blue ... ?
I ask that because when I play some dsf 64 / 128 file, my DAC receive converted file and when I activate DoP , my DAC receive DSD file without conversion via USB ... So the switch ( dop ) in my understanding should be off ( grey ) to receive unaltered file but DAC RECEIVE PCM reconverted .. so my conclusion is both switches should be on Blue, who means no volume and no DoP .
I was somehow clear. DAC work with native DSD . On PC with all drivers installed and settings only DSD same files play with same message on screen USB DS 64, and when are converted the message could be USB 384 k ( depends on bit depth of the original file ) . Also on Moode settings as output I have USB 384 k converted file from dsf dff files - dsd 64/128/256 .
Here are my DAC specifications:
S/PDIF 24bit 44.1-192k PCM, DSD64
AES/EBU 24bit 44.1-192k PCM, DSD64
USB 32bit 44.1-384k PCM, DSD64-512
OPTICAL 24bit 44.1-176k PCM, DSD64
I2S (LVDS) 32bit 44.1-384k PCM, DSD64-512
Something is missing or switches are on right position and I have burnnn brain
Thank you for all patience
Looking forward .... after answers
Cristache
