syntax error near unexpected token `newline`
Postby Felix » 03 Apr 2022, 05:05
Felix
Re: syntax error near unexpected token `newline`
Postby Rachel Gomez » 02 Nov 2022, 06:51
If a syntax error appears, check to make sure that the parentheses are matched up correctly. If one end is missing or lined up incorrectly, then type in the correction and check to make sure that the code can be compiled. Keeping the code as organized as possible also helps.
Greeting,
Rachel Gomez
Rachel Gomez
Postby lioeniate » 15 Nov 2023, 03:56
lioeniate
