RuneAudio 0.6-beta for most Raspberry Pi models
Re: RuneAudio 0.6-beta for most Raspberry Pi models
Postby Beelzebassie » 16 Jul 2024, 10:26
With the new version, it looks like empty folders on the drive are added to the database as ghost folders:
(Trying to open them will just lead back to the 'Browse your library'-screen.)
Beelzebassie
Postby janui » 17 Jul 2024, 09:53
Postby janui » 18 Jul 2024, 09:27
Sporify Connect failing to start
Postby janui » 19 Aug 2024, 15:48
Hi All,
Spotify have modified their authentication mechanism. This was causing spotifyd, which is our Spotify Connect client, to fail. For the technically minded there is an explanation here:
Spotify also modified their metadata structure, which was also causing some problems.
The advised fix for spotifyd authentication and some changes to the RuneAudio metadata routines have been implemented.
You can get the latest fixes by updating the player (with this update the patch level will move to 6):
1. Go to the /dev menu - in the browser url enter http://<playername>.local/dev (e.g. http://runeaudio.local/dev).
2. Switch dev mode on - Scroll down to the 'Dev Mode' button and toggle it to ON, then click on the ‘Save Settings’ button below the toggle button.
3. When the UI comes back, click on the first ‘Save Settings’ button to activate the dev mode options.
4. Perform a git pull - Scroll down to the ‘Update RuneUI’ option and click on the ‘git pull’ button. The update will then be carried out and the player will reboot.
Postby Stephane » 13 Oct 2024, 16:41
Today I tried to use my player as a Bluetooth receiver. Pairing done with pain, I can now connect and send a stream but I get no sound.
I can see the time growing but I get silence.
What am I doing wrong? When I play a file or radio stream I have sound.
I have a HifiBerry Digi+ card.
Stephane
Postby janui » 14 Oct 2024, 14:30
Postby Stephane » 15 Oct 2024, 17:51
Stephane
Postby Stephane » 16 Oct 2024, 10:29
I found a bug (or at least a weird behaviour): when the bluetooth stream stops playing and the system returns to local playing then the online volume stops working on the touch screen (it works fine on the phone). I have to go to the MPD setup to enable the knob again.
Stephane
Postby janui » 17 Oct 2024, 15:26
Postby janui » 17 Oct 2024, 15:33
