IQAudIO Pi-DAC+ "plus"
Re: IQAudIO Pi-DAC+ "plus"
Postby Fin » 05 Nov 2014, 16:40
Fin
Postby Stwert » 05 Nov 2014, 20:00
I found that sudo wasn't installed on my pi with the 0.3-beta.
I can't remember the exact commands cause I'm not used to arch linux, but you have to update the repositories with a pacman command and then install sudo with another pacman command. Hopefully someone else can chime in.
Not sure why sudo doesn't come with the latest version, it seems that's a standard command?
Stwert
Postby Fin » 06 Nov 2014, 16:13
Fin
Postby gswg » 13 Dec 2014, 18:03
Just to clarify - the Pi-DAC+ does not passthrough all signals - the Serial pin signals, for example, are not routed. If you need to use the serial port then please remove the Pi-DAC+ and use the standard Pi's GPIO signals.
Best regards,
Gordon
gswg
Postby lagrange » 19 Jun 2016, 17:44
lagrange
Users browsing this forum: Bing [Bot] and 1 guest
