Help with script at the boot of runeaudio
Postby amadeus74 » 08 Nov 2014, 01:12
Hi to all.
I have one Raspberry Pi connected via HDMI to my TV. With two SD card, I run Openelc for the film / video and Runeaudio for the music.
I utilize two SD card because at the moment the dual boot with Berryboot don't work.
I have created a very little script that powerdown the HDMI output of the PI, and I want this script to bo executed before the login screen of Runeaudio, but have not been able to make it work: the script is loaded and appear on the list of command during the system startup, but the screen don't power off.
If I run the script manually via ssh after the system is ready, before to login, the HDMI switch off.
Any help for this request?
Thanks for any suggestion.
amadeus74
Re: Help with script at the boot of runeaudio
Postby Thak » 08 Nov 2014, 07:52
i remeber doing something similar for another SD of mine. For that i edited /etc/rc.local and add my command just before "exit 0" line
You could try this!
Hope it helps
Thak
Postby amadeus74 » 08 Nov 2014, 14:24
amadeus74
Postby tux » 08 Nov 2014, 15:04
Runeaudio is based on archLinux which uses systemd, so I am not sure that rc.local will work for you.
Sent from my Oneplus One
tux
Postby hondagx35 » 08 Nov 2014, 15:23
Postby Thak » 08 Nov 2014, 15:41
Ho, yes it was with a debian os my trick... I forgot rune was on archlinux... Sorry :/
Thak
Postby amadeus74 » 10 Nov 2014, 21:47
amadeus74
Postby hondagx35 » 10 Nov 2014, 22:41
- does your script start with #!/bin/sh
- are your file permissions right?
frank
Postby amadeus74 » 14 Nov 2014, 23:57
amadeus74
