[SOLVED] Issue with GUI in smaller screens
Postby mp29k » 13 Jan 2015, 18:11
When I browse a folder (Artist) with several records, the options of "Add and Play", "Add, Replace and Play" and "Refresh Folder" are cut off. The only option is "Add". This seems to be caused by the view able window now allowing scroll beyond the last album or song in the list to allow those options to come into view. The work around is just to add and then manually select the song in the playlist tab, but, it is not intuitive, and clunky.
Potential solution, default the selection dialog of the 4 choices to bottom justify rather than top justify with the item name, this will force all options to be visible.
If this is unclear, I can send some screenshots.
mp29k
Re: Issue with GUI in smaller screens (phones, small tablets
Postby ACX » 13 Jan 2015, 20:43
Hi mp29k,
which version of RueAudio are you using? I remeber to have solved that problem months ago, it was already fixed in 0.3-alpha...
Postby mp29k » 14 Jan 2015, 01:04
I am on BBB platform, so if I'm not mistaken, the latest is 0.2. Is 0.3 coming soon for BBB?
mp29k
Postby ACX » 14 Jan 2015, 10:43
Ok that explains everything. BBB will receive directly the upcoming 0.4 update.
Postby mp29k » 14 Jan 2015, 14:24
Thanks ACX, love your software.
mp29k
Return to Bug report
