I am using the runeaudio 0.2 beta on a raspberry pi. For the output I use the miniStreamer (http://www.minidsp.com/products/usb-aud ... nistreamer) which is a usb audio to spdif interface. The spdif is fed into my dac, as all my digital sources. My flac files are on a local usb disc.
The setup works very well and gives good sound, no cracks or anything, at least with 44.1kHz files.
But: the volume is very low, I think more than 6dB lower than e.g. the identical hardware setup using other OS/Software Packages (e.g. Volumio, Openelec) and than my other digital sources.
As it is not a hardware problem - the hardware works perfectly, the volume must be reduced anywhere in the software.
Any hints, where this might be?
Best regards
Floric
