Fading-out over time (Baby player)
Postby cyber7 » 30 Jan 2015, 10:35
Hi Guys
Please could you guys tell me if there is a "sleep" option, if not how would I inject an option like that?
I am busy building a RPi with RuneAudio for my baby's room (arrival in 7 weeks :shock: ) and would like a function where it takes about an hour to take the volume from 100% to say 30% and leave it there...
Thanx for a very nice environment
cyber7-out
To err is human, to err again is machine!
cyber7
Re: Fading-out over time (Baby player)
Postby ACX » 01 Feb 2015, 02:04
Postby cyber7 » 01 Feb 2015, 06:31
Hi ACX
Thank you for the good wishes. It is my first and we are very excited! And, yes I have been MIA for a while due to work-restraints...
Thanks for the suggestion. I ended up re-writing a 'wicked' script to achieve the fade. I would like to know if there is a place that I can do an add-in into the GUI. Would be nice to be able to do this from the front-end :)
At this stage what I have (see aubreykloppers.wordpress.com for the full write-up) is a script that lets you fade from your current volume to a next volume over time and keep it there.
One of the major obstacles I currently face is to add "bc" (pacman -S bc) without doing a "pacman -Syu". If I do a "pacman -Syu" and restart the system, the network does not want to work anymore... (But whilst not restarting, "bc" does, however, work)...
kind regards
cyber7 (aka Aubrey Kloppers, South Africa)
cyber7
Postby ACX » 01 Feb 2015, 20:42
Postby cyber7 » 02 Feb 2015, 14:53
Ok, after doing some coding, I came up with the following (Now in Beta 1):
https://www.dropbox.com/s/4t6pcyez0r4oo ... 1.tar?dl=0
NOTE1: Install BC (with "pacman -S bc") before starting
NOTE: MPC and BC values hardcoded.
extract the file in /var/www then open your browser with:
http://<your rune ip>/slide/slide.php
It will bring up a page with values you have to enter. It is very self explanatory :) this is still very early in the coding and I need to make it Mobile Friendly. What it will do is slide the volume from a start value to an end value over time.
Future release:
1. Read the current value (volume) and make it the start value. - Done
2. Make the code Mobile Friendly.
3. Integrate into Rune as an add-on. (Will need big help here :) )
4. Only allow numeric values. - Done
kind regards
cyber7 (aka Aubrey Kloppers; Cape Town; South Africa)
cyber7
