Stays in connecting (Spotify).
Postby Moller » 05 Jan 2015, 23:31
Hi there,
I have an issue where the RuneUI stays in connecting to Spotify and I can do nothing.
Does anyone know how to get out of this stage?
Can it be done with a command after login with SSH?
It always boots up and stay in this stage.
Please help.
Kind regards,
Henrik
Moller
Re: Stays in connecting (Spotify).
Postby hondagx35 » 06 Jan 2015, 01:03
Postby jack » 13 Feb 2015, 18:06
Dear Frank,
I got the same issue with Henrik.
But, I don't know what is SSH? I am using Raspberry Pi B+ and I have no Linux knowledge.
Can you give me more description to solve this problem?
Henrik, have you solved the problem?
Jack
jack
Postby hondagx35 » 13 Feb 2015, 18:20
Hi Jack,
with SSH you get access to the command line of your Raspberry Pi from another computer on the same network.
Depending on the OS you are using try or
An other possibility is to connect a keyboard and monitor to your pi.
For both variants you need to enter username and password:
user: root
password: rune
Now you can enter the commands from above.
Postby jack » 14 Feb 2015, 17:29
Dear Frank,
Great, it works!
Thank you so much.
But still got problem to jump to Spotify. It will happen again!
Last night I have to format the SD and re-install the Runeaudio to solve my problem and now the new problem is the wireless can not to link via PC.
When Eth. wired I can see Wireless and Eth0 both active in different IP. But can not connect it via wifi after reboot like yesterday.
How to setting the wireless for cell phone control via Android?
Sorry to ask more!
Best regards,
Jack
jack
Postby sesheron » 08 Apr 2016, 18:56
I ran the above command, and after reboot, I see it starts to load the default MPD, but after a second goes back to Spotify. At which I get the infinite connecting wheel.
I don't want to reinstall, as I run a wifi connection, and don't want to have to reinstall everytime something goes wrong.
Is there another option?
Where do I disable spotify entirely, with SSH?
sesheron
Postby hondagx35 » 08 Apr 2016, 19:55
Postby sesheron » 08 Apr 2016, 21:44
sesheron
Postby hondagx35 » 08 Apr 2016, 22:29
Users browsing this forum: No registered users and 67 guests
