Raspberry pi 2 and hires files
Postby DonGui » 03 May 2015, 13:50
Hi all,
I've only seen a couple of posts speaking about pi 2 and hires files handling (like 192/24). The posts were pretty positive, but I wondered if we could get a more detailed confirmation that pi 2 is ok with hires files, unlike pi 1. Anyone willing to share some input ?
DonGui
DonGui
Re: Raspberry pi 2 and hires files
Postby jazzaj » 03 May 2015, 21:23
I read all type of hires files on my RSPI2 : 24/44.1, 24/96, 24/192 even some 24/176 without any problems and a great pleasure !
Odroid C1+ (/regulated linear PSU) > Audio-gd NFB-1 (with Amanero384 combo) > Audio-gd Precision 2 > Triangle Lyrr 222
jazzaj
Postby hondagx35 » 03 May 2015, 21:57
my setup
- RP2
- HifiBerry DAC+
- wired network
- music library on NAS
plays up to 24/192 without any problems.
Postby DonGui » 05 May 2015, 14:44
Thanks for your input, I'll be buying a RPI2 soon !
DonGui
DonGui
Postby nopphong » 06 May 2015, 07:35
I reply to confirm that Pi 2 work really good with hires files.
All 24/96 24/192 and dsd64 playing really good without stutter. It work much better than pi b+.
nopphong
Postby naggie21 » 07 May 2015, 22:57
Hi, I'm new here, and made a profile based on this post.
An RPi 2 and a HifiBerry sonud like a really cheap way to get hires audio on my old stereo system. But is there a case, that can hold both the Pi and the HifiBerry in one?
The idea is to hook i up with my old trusty Denon PMA-1315r with a set of Dali Suite 2.8 speakers.
EDIT: And by the way, does a RPi 2 with the HifiBerry DAC+ need a 2 Amp PSU or is a 1 Amp enough?
naggie21
Postby neanderthaler » 09 May 2015, 10:54
neanderthaler
Postby BrianH » 12 May 2015, 20:37
When using files from a USB stick up to 24/192 Pi2 was fine.
Today I put a NAS together and over WiFI, WiPi dongle, anything larger than 16/44 stutters. Substituting an ethernet cable Pi 2 is happy again.
Are there any settings for WiFi I can alter to improve performance? I have trailed an ethernet cable across the room to test but it isn't really practicable
I have tried doubling RSIZE and WSIZE, slightly better but not eliminated
BrianH
Postby duffbeer » 25 May 2015, 19:26
Pi2 plays 352.8kHz DSF files without any problem, through Wired LAN, from SMB share.
duffbeer
Postby Aquarius » 26 May 2015, 11:08
-- Aquarius
Aquarius
