Unable to mount NAS
Unable to mount NAS
Postby nic » 16 Dec 2013, 21:11
I'm getting a lot of instability with 404 messages and eggtimers and I'm intermittantly unable to access the database tab . Occasionally I get the prompt 'job failed background worker busy' and can only get a response by clicking the runeaudio button . Have tried both file formats and receive the message 'username specified with no parameter' which I'm unable to resolve . No issues when using raspyfi . Any ideas what is causing this ? Thanks
Nic
Pi3 , Kali / Piano 2.1 (with dedicated choke input PSU) ----6SN7 beta follower---BUZ900P choke loaded source follower---Beyma 15XT in 230l cabinets/TPL150H AMT .
nic
Re: Unable to mount NAS
Postby nic » 16 Dec 2013, 22:31
Have started afresh and no longer have the 404 issues etc but still unable to mount the nas , I think the SD card was faulty out of the box . Database config is set for NFS , checked and double checked the path is correct compared to the screenshot of the same page in raspyfi yet still have the dreaded red 'x' . Have updated MPD database , rebooted and also tried a power reset . Issue remains . Help
cheers
Nic
nic
Postby Orion » 16 Dec 2013, 23:29
Hi Nic,
please follow this guide , collect you debug informations and post them here.
Also try to re-enter in the mount point details (simply by right-clicking on the mount-point) and take a look at the page top, you should find a box with some other debug informations about the mount error, post them here.
Thanks.
Orion.
- Embedded Hi-Fi music player
Orion
Postby nic » 17 Dec 2013, 00:09
Thank you , I've got high hopes for this , really enjoying raspyfi and ended up building a new pair of amps especially for it :) When I edit the mount point I get the following : ' Last system mount error mount.nfs: access denied by server while mounting 192.168.1.5:/public' . This exactly as I had it entered in raspyfi , I have also changed the 'p' in 'public' to upper case and still get the same error
In debug mode , see results below
###### System info ######
Linux version 3.6.11-18-ARCH+ (nobody@) (gcc version 4.7.2 (GCC) ) #1 PREEMPT Mon Oct 21 01:15:42 CDT 2013
system load: 0.10 0.07 0.03 1/79 386
HW platform: RaspberryPi (01)
playerID: 01ce22edff80022f9116a029273a35ec69
###### Audio backend ######
Advanced Linux Sound Architecture Driver Version 1.0.25.
Card list: (/proc/asound/cards)
0 [ALSA ]: BRCM bcm2835 ALSbcm2835 ALSA - bcm2835 ALSA
bcm2835 ALSA
1 [D20 ]: USB-Audio - DIYINHK USB Audio 2.0
DIYINHK DIYINHK USB Audio 2.0 at usb-bcm2708_usb-1.3, high speed
ALSA interface #0: (/proc/asound/card0/pcm0p/info)
card: 0
device: 0
subdevice: 0
stream: PLAYBACK
nic
Postby nic » 17 Dec 2013, 01:27
Some slight progress , by chance I removed the source name and now I have a green tick :) Trouble is that after updating MPD and rebooting , I'm unable to view any NAS files
cheers
Nic
nic
Postby ACX » 17 Dec 2013, 09:22
Postby nic » 17 Dec 2013, 12:45
After updating the database last night , still the same status this morning . On Raspyfi the spinning icon is there when the database is updated , on Runeaudio I get no spinning icon , only a box at the top right hand side to say the update has begun .
cheers
Nic
nic
Postby Orion » 17 Dec 2013, 13:15
Orion
Postby nic » 17 Dec 2013, 16:26
nic
Postby ACX » 17 Dec 2013, 22:25
Return to Bug report
