IR Receiver & Remote support
Re: IR Receiver & Remote support
Postby yjo » 15 May 2015, 05:23
Maybe that does not mean double press, but means the character of your remote controller.
Your system looks working well, so try combination with irexec.
yjo
yjo
Postby eratical » 16 May 2015, 00:42
Thx for your help yjo.
Unfortunately, it’s a double tap. When i configure irexec, commands are executing twice.
As i see on others forums, it’s a frequent issue. I will try to resolve but i’m not familiar with Arch
eratical
Postby yjo » 16 May 2015, 12:24
Sorry, I don't know what is important. But I suppose the above problem is caused by lirc (and/or related) setting(s) and not by archLinux itself.
BTW, I traced my job (and found some mistakes in the older posts :shock: ).
I rewrote the simple step-by-step instruction of IR remote control.
Good luck!
yjo
yjo
Postby XploD » 16 May 2015, 19:17
Thank you for helping us and for your time! As soon as I find some time, I will try this from scratch following your new tutorial.
In the meantime, I went a little further with GPIO and added LCD display with keys. I'll write tutorial and give code probably on my site and then give it here on forum.
Music taste:
Audio source: Raspberry Pi 2 + Sabre ES9023 DAC + WD 500 GB HDD + TP-Link TL-WN722N Wi-Fi + D-LINK Dub H7 USB hub
Hi-Fi:
Mixer: Nady Audio MM-242
Misc: Tube Stereo Vumeter (Magic Eye)
XploD
Postby mishgun » 21 May 2015, 15:11
mishgun
Postby XploD » 21 May 2015, 17:42
Music taste:
Hi-Fi:
XploD
Postby yjo » 23 May 2015, 11:42
yjo
Postby phuongdk » 25 May 2015, 09:23
phuongdk
Postby hondagx35 » 25 May 2015, 18:03
if someone has problems with getting lirc to work, please take a look .
"irrecord" doesn't seem to work proper on arch-linux-arm.
The config files recorded with irrecord are not correct at all.
I copied my lircd.conf from an other machine and all works just fine now.
Postby yjo » 26 May 2015, 14:47
yjo
Users browsing this forum: No registered users and 58 guests
