Can't change Volume Control
Postby deef » 10 Aug 2015, 17:25
I'm stuck at software volume control.
When ever I try to change it to either disable or hardware it just reverts right back to software.
Plus I get this message too:
I tried to put in a 1 in the above field, but doesn't change anything.
I did a git pull to update the RuneUI.
Here is the debug info: http://pastebin.com/smEtq5Lv
deef
Re: Can't change Volume Control
Postby ACX » 10 Aug 2015, 21:16
Hi deef, if you see those options you are using the ("dev" branch). We're work in progress on some parts and that's one of them, so you'll probably experience weird behaviours until it's completed...
Postby chrisf4lc0n » 13 Aug 2015, 08:31
It works for me but crashes the front end (WebUI), the ssh is still active and all processes are still running, even NGINX, but the web becomes unresponsive, I normally restart the NGINX and it comes back with all the changes applied.
chrisf4lc0n
Raspi 1 B+ with HiFiBerry DAC and Microlab Solo 6C Speakers on Van Damme Cable
chrisf4lc0n
Postby chrisf4lc0n » 13 Aug 2015, 08:57
Changing to the dev branch sorted the problem out, now I can change the Volume Control on the fly! Thanks!
chrisf4lc0n
chrisf4lc0n
Postby deef » 27 Aug 2015, 10:24
deef
Postby hondagx35 » 27 Aug 2015, 11:52
