Dorky question - MPDroid
Postby kraigo » 08 Apr 2014, 04:08
I have seen posts suggesting that using MPDroid to control Rune should work. I am not having any luck. I just want to control my Raspberry Pi that is running Rune, not stream back to the phone. So I input the MPD-Server IP Address (fixed via IP address reservation at the router) and let it choose the default port (6600). I leave the streaming server IP address blank.
MPDroid reports that it can't connect to the server. I'm sure it's me being new to MPD and all this stuff, but it's fun and I'm learning, so please throw me a bone on this one.
Thx.
KO
kraigo
Re: Dorky question - MPDroid
Postby ACX » 08 Apr 2014, 08:35
Hi kraigo, that should work because the default port is 6600, so you only have to put the correct IP address in MPDroid Settings screen. Have you tried to configure "Preferred connection" and also "Default connection" settings? That's a bit tricky, I also had some troubles the first time I had to configure that.
Postby kraigo » 08 Apr 2014, 17:30
Well that _WAS_ dorky! For some reason the WiFi on my phone was turned off so I was outside the firewall.
KO
kraigo
Postby ACX » 08 Apr 2014, 20:45
Lol, I was sure it was something like that :D
Postby exetico » 28 Feb 2015, 13:20
Hello...
I'm testing MPD with now, just to try controlling the volume (The option is grey in the interface, even if software is set in MPD settings and mpd.conf). But then i'm trying to connect to the MPD, i can't connect. Using the default port, and the right IP.
In on the same network, without any firewall or so.
Running the latest version of Rune (0.3beta).
What can it be? (For me it's actually not a problem, but my PCM2704 can't volumecontrol with now from the GUI, so i need to try something else. Alsamixer is working fine :-/ )
Raspberry Pi with Rune, Synology NAS, OVH Debian Fileserver and a Shuttle HTPC.
exetico
Postby ACX » 28 Feb 2015, 19:26
Postby exetico » 11 Mar 2015, 12:23
exetico
Postby ACX » 11 Mar 2015, 15:49
Users browsing this forum: No registered users and 76 guests
