Web Radio stream format
Postby washburn_it » 11 Oct 2015, 14:53
I'm a new user of RuneAudio, I'm going to use it for a "Car Media Center".
I'm doing some tests to better know RuneUI and I would like to add some Web Radio, mainly Jazz and Blues radios.
I found some web radios (Jazz24.org for example), tried to add their URL, clicked on "play" button but nothing happened.
The address of the above mentioned radio is http://icy1.abacast.com/kplu-jazz24aac-64.m3u but it didn't work.
So I wonder what format should be the stream.
Thank, regards.
Roberto
washburn_it
Re: Web Radio stream format
Postby °pdi° » 11 Oct 2015, 16:11
Hi Roberto,
you can get the streaming-url e.g with vlc. Just add your stream in vlc and in menu->tools->media-info (or so, i use vlc in german translation), you will see in "location" the streaming-url. In case for your example it is "http://icy1.abacast.com:80/kplu-jazz24aac-64".
Klaus
°pdi°
Postby washburn_it » 13 Oct 2015, 10:45
Thanks Klaus, I will try what you suggested when I'm at home.
Roberto
washburn_it
