Volume control for Airplay stream?
Postby den_hr » 27 Nov 2015, 13:04
I'm trying to use Airplay (it's still somewhat flaky, but generally works), and one thing is bugging me:
I can't control the volume in the RuneUI - the volume "circle" is greyed out.
I can still drag the volume slider, although it's greyed out - but it has no actual effect on volume...
The only way to control the volume is from the streaming device - in my case it's a Mac Mini running iTunes.
So, basically, I start iTunes on the Mac, select "runeaudio" as the output, and it plays - the RuneUI shows the track name, artist, etc, but I can't control the volume in the RuneUI. The only way to control the volume is the volume slider in iTunes on the Mac....
Would it be possible to control Airplay volume directly from RuneUI?
As for hardware info, here's the debug info:
den_hr
Re: Volume control for Airplay stream?
Postby hondagx35 » 27 Nov 2015, 18:09
Hi Denis,
at the moment this is not possible.
The next version will come with a better solution for this.
Postby den_hr » 27 Nov 2015, 18:18
den_hr
