Want to use USB & Jack outputs
Postby djsebfr » 07 Nov 2016, 10:36
Is there a way to use both outputs (USB/SPDIF & Jack), at the same time with rune audio/rpi 3 ?
Thanks in advance.
djsebfr
Re: Want to use USB & Jack outputs
Postby hondagx35 » 07 Nov 2016, 11:21
Postby djsebfr » 07 Nov 2016, 12:24
Thanks you very much hondagx35, it working good !!
I am using the both outputs at the same time like this :
-RPI3 > USB SPDIF > Digital Amp "without subwoofer output"
-RPI3 > Jack > Active Subwoofer
have fun with Runeaudio.
Bye
djsebfr
Postby dror » 07 Nov 2016, 14:47
Very intersting.
I would like to do this as to examplify the differences in audio quality between my Hifiberry DAC and the normal Rpi output.
Frank & anybody
Can I do the same for the Hifibarry DAC output?
If so, do you think it has any affect over sound quality of the the DAC? (crosstalk, interferences etc..)
Dror
dror
Postby hondagx35 » 07 Nov 2016, 17:28
Postby dror » 08 Nov 2016, 11:08
dror
Postby hondagx35 » 08 Nov 2016, 13:21
Postby dror » 08 Nov 2016, 14:27
Ok thanks. Just found your answer here -
rpi-runeaudio-wifi-as-accesspoint-control-t972-50.html#p17132
before I noticed your respond. Cheers.
Anyway, first quick attempt showed the jack output is has EXTREME noise (square wave like) when both outputs are active and playing.
dror
