Waveshare 7" Touch Screen (B) Not Working
Postby neimaralves » 09 Apr 2018, 04:26
Hi Guys. My name is Neimar.
I am very new on this field, just have basic skills but not enough to finish my job. I got a raspberry pi3, a HiFiBerry DAC+ and a Waveshare 7" Touch Screen (B) 800x480. "Everything is working" fine, but my touch Screen it doesnt work, so, i found a bunch of tutorials, i have tryed so many times with different codes in the config.txt as well as Raspbian or Raspbian Jessie. but a cannot do it.
Can you guys help me to fix this?
Thanks a lot.
neimaralves
Re: Waveshare 7" Touch Screen (B) Not Working
Postby neimaralves » 11 Apr 2018, 01:25
Hi guys!!!
Does anyone to help me please? i am so excited to see Runeaudio running on my system.
Thank you so much,
neimaralves
Postby janui » 11 Apr 2018, 11:28
Hi neimaralves,
I assume its version using the HDMI connection. If so, it should work with this image: runeaudio-0-4-beta-for-raspberry-pi2-3-t4434.html#p19960
It should be just a matter of switching it on via the Settings UI.
Postby Stephane » 11 Apr 2018, 12:52
Stephane
Postby neimaralves » 15 Apr 2018, 16:06
Hi janu and Stephane, how are you guys?
First of all thank you so much for answering my post. So, I did exactly how you described I am using the same Runeaudio image and I included the lines in my config but it doesn't work. Maybe my Lcd has some problem... :roll:
neimaralves
Return to Compatibility list
