Waveshare Spotspear 3.5" Touch Screen Working with Rune
Re: Waveshare Spotspear 3.5" Touch Screen Working with Rune
Postby kb06 » 17 Jun 2017, 17:59
kb06
Postby clarindo » 05 Jul 2017, 12:34
I think this question has been left aside by administrators, but if anyone has this same problem and gets it resolved, let us know.
Thank you!
Clarindo
clarindo
Postby hondagx35 » 05 Jul 2017, 15:21
Postby rlsten » 11 Jul 2017, 20:08
rlsten
Postby rogercorrea » 09 Aug 2017, 02:54
But the RuneAudio interface is shown for you?
For me the 3.5 display worked but he stopped in login console. Don't showed the interface for me.
I'm using the Waveshare 3.5 display and Rpi 2 model B.
rogercorrea
Postby rogercorrea » 09 Aug 2017, 03:54
Worked for me now.
I found the fbturbo driver in my LCD3.5 Waveshare image and copy to /lib/xorg/modules/drivers and solved my problem.
Thanks for shared.
In attach I uploaded the files for it.
drivers.tar.gz
Zip file with the drivers for fbturbo for work with the Waveshare 3.5 display and RuneAudio.
(58.15 KiB) Downloaded 817 times
rogercorrea
Postby ckiley3 » 01 Sep 2017, 07:22
I am having troubles with this as well, They just put out a new RuneAudio so maybe that is my issue? All i get is the same white screen
ckiley3
Postby nikosr6 » 02 Sep 2017, 20:22
nikosr6
Postby luthier » 03 Sep 2017, 12:10
Hi everyone, i am new to this forum and the RuneAudio player and i recently bought a TFT touch screen off ebay but i am having the following issue:
On RaspberryPi 2 and using the latest version of RuneAudio(beta) i login normally to access the console [User:root Pass:rune] but i can not type commands because the system boots into the player even after i log in to have terminal access!!
Trying to run this: pacman -Sy xf86-video-fbturbo in order to get my TFT unstuck from the log in screen
Always after login to terminal a white screen appears and i am inside the player before i can type any command
If anyone knows how to make the terminal stay i would greatly appreciate it
luthier
Postby rlsten » 03 Sep 2017, 15:27
One suggestion: Look under Settings in the Rune Audio Menu and make sure Local Browser is set to off.
rlsten
