Web interface on iPad 1
Postby Stymieddd » 07 Aug 2014, 22:04
I just purchased an iPad 1 to run as a dedicated controller for Rune Audio. It loads the web interface page (dark in the background) but has the spinning circle that runs endlessly. I'm using 0.3a. Is there a fix for this or is the iPad too old?
UPDATE: I have used various browsers, still with the same problem. I tested Volumio 1.2 and 1.4, and they work. I would rather have Rune Audio.
Stymieddd
Re: Web interface on iPad 1
Postby Stymieddd » 10 Aug 2014, 01:39
It must have something to do with the iPad 1 being too old. Something with the javascript (400). The iPad 2 works fine. So goodbye iPad 1!
Stymieddd
Postby rodgersan » 10 Aug 2014, 16:17
rodgersan
Re: R: Web interface on iPad 1
Postby ACX » 11 Aug 2014, 15:03
If Chrome can be installed and runs decently on the iPad 1, it would serve you great. Moreover, you could use the feature that works great with RuneUI.
Postby Stymieddd » 12 Aug 2014, 01:30
Thanks for the replies. I tried Chrome and it either did not work or was to new to run on the iPad 1, I forget. I tried the Add to Homescreen and no luck there either. I sold the ipad 1 and bought an iPad 2 instead. That should solve the problem :D .
Stymieddd
