Webradio plays for 3-4 seconds then dies...
Postby KHatfull » 18 Oct 2017, 03:27
...and the UI locks and eventually have to power cycle the box.
Haven't played webradio in a while so couldn't tell you when this staerted. On 0.4 20170229
Any quick thoughts before I delve deeper?
Keith
Synology DS214+ -> RP3 -> Hifiberry Digi+ -> Audio-Gd NOS1704 (coax) -> Audio-GD C-2 preamp/headphone amp ->
1) Yamaha M-4 Power Amp -> Energy Pro 22 Speakers OR 2) HiFiMan HE-400i
Audio Nirvana!!!
KHatfull
Re: Webradio plays for 3-4 seconds then dies...
Postby surfninja » 18 Oct 2017, 15:55
I listen to my web radios stations all the time. I hardly listen to my library any more. You might want to verify the web radio station is not dropping off. I use xiiaLive app on my phone to stream my stations when I'm not in my listening room.
Or post your station and see if others have the same issue.
I don't think runeaudio is the problem.
rAudio 1, Raspberry Pi 2B
rAudio 1, Raspberry Pi 4B
rAudio 1, Raspberry Pi Zero W
surfninja
Postby janui » 18 Oct 2017, 22:30
Hi KHatfull,
If you are using a WiFi Network connection this could be the problem, test by using a wired connection. The other thought is power problems, but I would expect this also to cause problems with mpd playback, therefore unlikely. I don't expect this to be a Rune problem, more likely to be envoronment or connection related.
